THINK OUTSIDE THE BOX 710 Posted August 1, 2009 Report Share Posted August 1, 2009 is this a 510 car or a wagon fuse box it has a blue wire hooked up to the a/c fuse is this wire important?. I have a engine harness but it doesn't have a connections for the blue wire[/img] Quote Link to comment
Cuts metal like mad Posted August 1, 2009 Report Share Posted August 1, 2009 They had the same fuse box... but I know that not all the wires coming out are used... Quote Link to comment
THINK OUTSIDE THE BOX 710 Posted August 1, 2009 Author Report Share Posted August 1, 2009 so can i use this fuse box on my 72 wagon? Quote Link to comment
Cuts metal like mad Posted August 1, 2009 Report Share Posted August 1, 2009 Don't see why not. :D Quote Link to comment
banzai510(hainz) Posted August 1, 2009 Report Share Posted August 1, 2009 not all fuse boxes are the same. But can be made to work the red /yelllow wire is for the lights. You have to see if the feed wire(power from the fusable link or where the wire comes from the starter lug go to and see if the copper strip is a 2 pc on the inside or a 1 pc. I will assume yours is a 2 pc since it has the red/yellow wire MY fuse box on my red car has only 1 big white feed wire going in to the copperstrip under the fuse box then it break out and feeds the Light side of the fuse box. the blue wire is the aircond wire but poeple can use this as a 12v swichable key power for sreareos or a eleltric fuel pump. Just need to unwrap the wire and pull it out. If you want to run the red/yellow wire you have to hook it up to the starter lug to get the lights to work. Im not familiar with wagon harness but make sure everything works including the brake lights(belive it or not that is powered by the HORN fuse) Quote Link to comment
THINK OUTSIDE THE BOX 710 Posted August 4, 2009 Author Report Share Posted August 4, 2009 NICE!!!!!!!!! thank you guys for the help Quote Link to comment
