dayton100 Posted September 21, 2007 Report Share Posted September 21, 2007 does anyone know from first hand experience if the exterior door handles from the front interchange with rear 4 door and wagon rear door handles? are they all exclusive to being left and right side? :confused: let me know thanks Quote Link to comment
fiveoneohray Posted September 22, 2007 Report Share Posted September 22, 2007 On the 510 the front handles are only front and they interchange with 2dr or 4dr The rear handles are only rear and are interchangeable between wagon or sedan. The left and right handles can be swapped to either side of you move the tab that makes the handle do its job (dunno what the correct name of the tab is). The tab is secured with a 'e' clip. You will find the tab is usually really rusty and very fragile. Its also super hard to get unhooked. Quote Link to comment
dayton100 Posted September 23, 2007 Author Report Share Posted September 23, 2007 Thanks Ray, i figured you were the one who would have the answer. later Quote Link to comment
dayton100 Posted December 2, 2007 Author Report Share Posted December 2, 2007 I know this is real old but anyone have a set of four for a 4door or wagon in excellent condition they'd be willing to let go or have all the nissan part #'s let me know thanks Quote Link to comment
5tinguy Posted December 2, 2007 Report Share Posted December 2, 2007 Outside door handle assy. part numbers are right front-80605-23100, left front-80606-23100, right rear-82605-23101, supers 82605-23100, left rear-82606-23101, supers 82606-23100. I do not think they can be swapped from side to side, but the fronts are the same for 2door and 4 door. Quote Link to comment
Icehouse Posted December 3, 2007 Report Share Posted December 3, 2007 On the 510 the front handles are only front and they interchange with 2dr or 4dr The rear handles are only rear and are interchangeable between wagon or sedan. The left and right handles can be swapped to either side of you move the tab that makes the handle do its job (dunno what the correct name of the tab is). The tab is secured with a 'e' clip. You will find the tab is usually really rusty and very fragile. Its also super hard to get unhooked. I broke my drivers handle the other day, I had to switch it out with a passenger handle I had. That stupid "rod" is a bitch to get out!! in the I was victorious :D Quote Link to comment
5tinguy Posted December 3, 2007 Report Share Posted December 3, 2007 So they can go side to side. Thanks for clearing that up. Good to know in case one side is not available anymore. Quote Link to comment
bucketoval Posted December 13, 2007 Report Share Posted December 13, 2007 po shaved the doors on 72 2 door 510. i found i guy in town that has 240z part will the door handle and locks fit? or does someone are a set of door they do not need.:D Quote Link to comment
