turbo L series without fuel injection?
Braden
hey guys i was wondering would it be possible to boost an L20b using dual 44mm mikuni carbs? I have this set of carbs that i am going to rebuild, and i have a brand new motor that had 3 thousand miles on it and it was disassembled, honed, re-ringed, and re assembled, so i guess what im saying is new motor + carbs+ turbo, can it be done, can the carbs handle the boost or would they leak or worse, or could i somehow run the carbs before the turbo? i am trying to avoid swapping an sr20det and still gain some power, i had planned on using the carbs in conjunction with a web cam racing profile camshaft
  • Replies 2
I would search since its been done and discussed so many times before.
Short answer is yes you can and has been done either way before or after. Each have their ups and downs.
Edited by 72240z
