Guest DatsuNoob Posted July 16, 2009 Report Share Posted July 16, 2009 (edited) slotted cross-drilled, they have the inner holes to fit the hub, otherwise same as pic in the link. wanting to sell for other phases of my build. Priced to sell, $100, local pickup please. New in box http://cgi.ebay.com/ebaymotors/Nissan-Datsun-620-720-P-U-Drill-Slot-Front-Brake-Rotors_W0QQcmdZViewItemQQ_trkparmsZ65Q3a12Q7c66Q3a2Q7c39Q3a1Q7c72Q3a1205Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem3a50439d33QQitemZ250454711603QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Edited July 16, 2009 by DatsuNoob Link to comment
datzenmike Posted July 16, 2009 Report Share Posted July 16, 2009 The '78-'79 and '80-'82? rotors will interchange and are thin and not vented. The '83 and up 720 are much wider and vented and same as the D21s. If those rotors are vented then it won't fit the 620 early 720 without converting to later 720 or D21 hubs. Link to comment
nis720 Posted July 16, 2009 Report Share Posted July 16, 2009 The '78-'79 and '80-'82? rotors will interchange and are thin and not vented. The '83 and up 720 are much wider and vented and same as the D21s. If those rotors are vented then it won't fit the 620 early 720 without converting to later 720 or D21 hubs. My 2wd 86' 720 rotors were different from the D21 rotors (different offset). But to make the D21 rotors work you will need D21 spindles only. The brakes and brackets bolted right up. Link to comment
