butcherboyjc Posted June 6, 2009 Report Share Posted June 6, 2009 I dont know how to properly add the external fuel pump not the electrical side but the plumbing of it. I want to keep the stock fuel tank if possible. My tank has the carb feed hose on the side of the tank and on top it has a hose for the vapor liquid separator that goes to a separete tank in the rear passenger side tire well. Could i use the top hose on the tank for the return line and the bottom hose for the fuel injection feed line and remove the vapor liquid separator. Also what fuel pump can you guys recommend. I will post pictures soon. Thanks.:) Quote Link to comment
butcherboyjc Posted June 6, 2009 Author Report Share Posted June 6, 2009 Disk brakes thanks to beebani's upper control arms. Great product. Quote Link to comment
sanitys Posted June 6, 2009 Report Share Posted June 6, 2009 (edited) I would also like to know what most people are using for a fuel pump. I was just gonna get one of the high flow walbro. Heres an example http://www.inlinefuelpumps.com/ I commented on the picture because thats exactly what I was thinking of doing for my battery. Great minds think alike :D what size battery are you using? I was gonna use one of these...smallest one optima makes http://www.amazon.com/Optima-Batteries-8071-167-YellowTop-Purpose/dp/B00075OSD8 Edited June 6, 2009 by sanitys Quote Link to comment
butcherboyjc Posted June 6, 2009 Author Report Share Posted June 6, 2009 Im using the d51 optima battery for a civic. Its compact size works great. Thanks for the link.:) Quote Link to comment
athoose Posted June 6, 2009 Report Share Posted June 6, 2009 I would guess that the stock pipe (bung) is not big enough on the 620 tank, neither in nor out. This would require enlargement. What size are your fuel lines on the KA. Then you need an external fuel pump though some add one in tank. You may want to consider a surge tank as well. It's not good for the fuel pump or engine, etc.. to be without fuel. Not sure that the 620 tank has any sort of baffles at all. Will you have to pass a safety/emissions test? Quote Link to comment
BEEBANI Posted June 7, 2009 Report Share Posted June 7, 2009 I ran the stock tank and stock lines on my truck with an inline MSD pump that I bought for $100 brand new. This setup works great and never had any problems with sloshing or starving for fuel. Quote Link to comment
butcherboyjc Posted June 7, 2009 Author Report Share Posted June 7, 2009 I would guess that the stock pipe (bung) is not big enough on the 620 tank, neither in nor out. This would require enlargement. What size are your fuel lines on the KA. Then you need an external fuel pump though some add one in tank. You may want to consider a surge tank as well. It's not good for the fuel pump or engine, etc.. to be without fuel. Not sure that the 620 tank has any sort of baffles at all. Will you have to pass a safety/emissions test? I figured that the size of the inlet and outlet bungs might be a problem but I was hoping other people with swaps got away with out having to modify the tank. I dont have emission or safety tests to pass. I ran the stock tank and stock lines on my truck with an inline MSD pump that I bought for $100 brand new. This setup works great and never had any problems with sloshing or starving for fuel. To plumb your return line from the engine, did you just use the hose that comes up from the drivers side and goes out back to the tank. I believe its a hose to purge fuel vapors. Quote Link to comment
BEEBANI Posted June 7, 2009 Report Share Posted June 7, 2009 I actually added a new hardline for the return, I had previously removed that one when I was running the L20 with the weber. Quote Link to comment
athoose Posted June 7, 2009 Report Share Posted June 7, 2009 I ran the stock tank and stock lines on my truck with an inline MSD pump that I bought for $100 brand new. This setup works great and never had any problems with sloshing or starving for fuel. So were you able to match up the inlet/outlet diameter on the fuel pump to correct the fuel line diameter difference or did you just run a mismatched diameter hose and crank it down? Quote Link to comment
BEEBANI Posted June 7, 2009 Report Share Posted June 7, 2009 Yes, I ran 5/16" hose and hardline everywhere that I needed to. Quote Link to comment
