Gonzo_Neko Posted June 4, 2009 Report Share Posted June 4, 2009 I've been trying to figure out what i would need to put an L20 into my 510 wagon. From what i've read before the L20 won't fit my stock L16 auto trany? Quote Link to comment
sssr20det510 Posted June 4, 2009 Report Share Posted June 4, 2009 the tranny should work (manual does) might need an auto flywheel for L20 and you need to use your oil pan and pick up tube off L16 Quote Link to comment
datzenmike Posted June 4, 2009 Report Share Posted June 4, 2009 If your 510 has a 3N71B auto then any 6 bolt 3N71B flex plate should fit your torque converter. The distance between converter mounting bolts should be 6.25" just to be sure. Six bolt flex plates can be found on any L20B equipped vehicle with automatic and also the 720 truck with Z22 up till '82. Z20E equipped 200sx '80-'81 (not the Z22 motor) In or around '82 Nissan introduced a locking torque converter and the flex plates are different shape. Quote Link to comment
Gonzo_Neko Posted June 4, 2009 Author Report Share Posted June 4, 2009 thanks guys .. i'll look into what trany i actually have Quote Link to comment
