Umai Kakudo Posted May 15, 2009 Report Share Posted May 15, 2009 Check out this company: http://www.vintageconnections.com/ They sell electrical connectors that match vintage Japanese motorcycle and cars. If you need to repair or upgrade your harness but want to keep it OG looking this is a good option. For a great example check out the thread I saw this on (VQ35 in S30 swap on HybridZ) Quote Link to comment
zerow Posted May 16, 2009 Report Share Posted May 16, 2009 I'm in love...:love: Where has this been my car's whole life...? Quote Link to comment
moparvwfreak Posted May 16, 2009 Report Share Posted May 16, 2009 i am so going to check this out. Quote Link to comment
Unclejesse88 Posted May 16, 2009 Report Share Posted May 16, 2009 I have ordered from Vintage Connections before. It is a great place to deal with. In fact, I just placed an order today. One note, he now sells non-latching connectors that are supposed to match the factory connectors. The latching connectors shown above are a bit different than the factory ones. Also, I recommend buying the ratcheting crimpers. With them, you can make a factory like crimp. Quote Link to comment
zerow Posted May 17, 2009 Report Share Posted May 17, 2009 ...One note, he now sells non-latching connectors that are supposed to match the factory connectors. The latching connectors shown above are a bit different than the factory ones. Point noted. I have accumulated many original Nissan plastic connectors over time, and just to have the pin removal tool and the correct male and female connectors for a rebuild will be a cost savings itself. Quote Link to comment
Unclejesse88 Posted May 18, 2009 Report Share Posted May 18, 2009 I personally like the fact that I can now make plug in harnesses for accessories added to the car. That means less cutting and splicing, and being able to revert back to stock if wanted. Things I had thought about were plug in jumpers for internally regulated alternators, and plug in replacement fuse boxes like the one pictured above, but with the correct connector on it. Quote Link to comment
Unclejesse88 Posted May 20, 2009 Report Share Posted May 20, 2009 Just to let you guys know, I received my package today. I can confirm that the Non-Latching connectors are a direct fit to at least the six pin alternator regulator plug. I will try out some of the others later. In speaking with the owner, he say that the 2.8mm pin connectors in the non latching style are in the works. Quote Link to comment
Moisabamf Posted May 20, 2009 Report Share Posted May 20, 2009 I personally like the fact that I can now make plug in harnesses for accessories added to the car. That means less cutting and splicing, and being able to revert back to stock if wanted. Things I had thought about were plug in jumpers for internally regulated alternators, and plug in replacement fuse boxes like the one pictured above, but with the correct connector on it. i 10000000000000000000000000 times agree with the above statement! imma order me a set of the non locking ones Quote Link to comment
Unclejesse88 Posted May 23, 2009 Report Share Posted May 23, 2009 I figured I'd throw this in this thread: The bullet connectors used from the factory on Datsuns are not the same as the jiffum crimp bullet connectors you buy from Pep Boys. Not only are they lower quality and not really insulated, but they are the wrong size. If you jam a pep boys male bullet into a datsun female bullet you will spread the female. Then when you buy these fancy replacement terminals, they will be loose connections. Ask me how I know. Quote Link to comment
zerow Posted May 24, 2009 Report Share Posted May 24, 2009 Ask me how I know. No need. I tried it years ago as a test, and it was an obvious FAIL. Quote Link to comment
Unclejesse88 Posted May 24, 2009 Report Share Posted May 24, 2009 All I can say is it wasn't me. It was the previous owner. All the problems arose when I replaced the large bullet with the correct size. Hit a bump and out it came Quote Link to comment
