sdsurf Posted May 6, 2009 Report Share Posted May 6, 2009 Help there is no bright link on my cloyes chain. What do I do? Quote Link to comment
sdsurf Posted May 7, 2009 Author Report Share Posted May 7, 2009 i just read that if i set it up so v notch at cam sprocket is just to the right of line and #1 is at true TDC I can put the chain on. Then rotate through a couple of times and see if it ends up in the same thought? Help! Quote Link to comment
motavated Posted May 7, 2009 Report Share Posted May 7, 2009 Cant you just get your old chain and count the distance between the markers and mark yours with a white out? Also look at the dimples? They could be different color "chrome"... The dimples too me are those metal lines that stick out on the side that holding the chain together. Quote Link to comment
banzai510(hainz) Posted May 7, 2009 Report Share Posted May 7, 2009 (edited) Taiwain chain!!!!!!!!!!! The brite links(japan ) are to make it idiot proof but put chain ON and rotate one full reveluttion and dial the crank back up to TDC keeping chain tight and see where the V notch ends up at. V should be right below the dash in center or V slightly to the right but still under the dash http://www.guba.com/general/search?query=hainz&set=5&x=0&y=0 one can take a old chain and if links are still visable lay the chains side by side stretched out and ink mark them spin motor around and get back to TDC on crank with tension on chain should look like this Edited May 7, 2009 by banzai510(hainz) Quote Link to comment
sdsurf Posted May 7, 2009 Author Report Share Posted May 7, 2009 Cant you just get your old chain and count the distance between the markers and mark yours with a white out? Also look at the dimples? They could be different color "chrome"... The dimples too me are those metal lines that stick out on the side that holding the chain together. My old chain doesn't look to have bright links either. But I will look at the dimples. Got to be some marker. If I find it I will share. Quote Link to comment
banzai510(hainz) Posted May 7, 2009 Report Share Posted May 7, 2009 just put head at TDC Motor block at TDC(place fron cover on loosely then remove) Put chain on and slack side guides the put front cover on and rotate motor a full turn back to O on crank and ck the marks. If off redo. Once you got it then you can seal and gasket it and spec all the bolt tightnes Quote Link to comment
sdsurf Posted May 7, 2009 Author Report Share Posted May 7, 2009 just put head at TDCMotor block at TDC(place fron cover on loosely then remove) Put chain on and slack side guides the put front cover on and rotate motor a full turn back to O on crank and ck the marks. If off redo. Once you got it then you can seal and gasket it and spec all the bolt tightnes Thanks Hainz! truly an l motor god!! Quote Link to comment
banzai510(hainz) Posted May 7, 2009 Report Share Posted May 7, 2009 Its ez once figured out Quote Link to comment
