S13 brake swap and knuckle width question
Faster7
These seem to be gaining in popularity, does anyone sell the caliper brackets to make it a bolt-on?
I know that the S13 knuckle and strut swap seems to be avoided because it would add too much track width, does anyone have a figure of how much exactly it would add?
  • Replies 4
It's actually the lower ball joint that adds the track. I think it is 1-1/2 inches total. There may be a different ball joint that doesn't do it.
You know the S13 kingpin angle is different than 510? More negative camber.
if you're talking about putting s13 calipers & rotors onto the 1200 struts than you need to ask the question at datsun1200.com
one of those guys could probably draw you up a template to diy
