Justin Posted May 1, 2009 Report Share Posted May 1, 2009 So I pulled my holley carb off and put the weber back on the L16. Now I have an ENORMOUS vacuum leak that I'm having an impossible time tracing. It runs when the accelerator is depressed, but as soon as you let off it dies. I feel like I've plugged every hole I can find, and it's only slightly improved. I'm probably just venting, but if anyone has any idea's on where to go from here, I'd love to hear 'em. Quote Link to comment
sssr20det510 Posted May 1, 2009 Report Share Posted May 1, 2009 Spray the base plate with carb cleaner see if it changes the idle Quote Link to comment
ggzilla Posted May 1, 2009 Report Share Posted May 1, 2009 It is difficult. The worst thing is it might just be an internal problem with the carb and not a leak of the gasket or manifold. I tried to explain my vacuum leak finding methods here: Vacuum Leaks. Hope it helps. Quote Link to comment
