Ryan@CiNcity Posted May 17, 2009 Author Report Share Posted May 17, 2009 im just running what i believe to be the stock SOHC maf and it is metal. as for a speedo its not hooked up. need to do something with the spot on the trans but none of my gauges work so ill probably just upgrade to all autometer gauges sooner or later. Quote Link to comment
dat521kid Posted May 17, 2009 Report Share Posted May 17, 2009 how about a little vid Quote Link to comment
Ryan@CiNcity Posted May 18, 2009 Author Report Share Posted May 18, 2009 well i did take it auto crossing yesterday and got some video. its not very good cause i hit alot of cones plus the datsun def. needs some upgrades in the suspension area.... ill see if i cant get it uploaded soon. Quote Link to comment
whisper3H Posted September 14, 2009 Report Share Posted September 14, 2009 Hey just of information, what maf are you running? Is it metal or plastic and does it have a number on the side like N-60 or N-62? N-60 is from a maxima and the N-62 is from the Z32. I don't recall what the stock ka maf was I just remember its metal and has a really low flow rate. Also do you have the speed sensor hooked up to the transmission/speedo cable? I bet there is another way round this than the must use #11 ECU in a 510. I bet its ether the speedo cable thing or the swap had the wrong MAF/ECU combo I can make a chip for those ECU's with no speed limit or rev limit. Which would fix the falling on its face at speed problem. The blank chips are getting a little hard to find these days though. -Avery I agree with you that it probably has to do with speedo from tranny sensor, it sounds like nobody is hooking this up, just the reverse lights.... Quote Link to comment
