oldsklminitrk Posted April 29, 2009 Report Share Posted April 29, 2009 Hey I keep seeing this post about making the Saturn 90 amp alternator work....Well I went out and got a 83 Datsun 720 alternator and it bolted right up.Granted its not 90 amps.....but it bolts up and its 55 amps vs the factory 35 amp one.I run a gel cell Maxda Miata battery and its plenty of juice to keep it running.Thought I throw this out there for everyone instead of doing the Saturn upgrade. Quote Link to comment
fastdadd Posted April 29, 2009 Report Share Posted April 29, 2009 i did the same thing...i had to take a grinder to the idler but if i had a shorter belt it would have been fine...works well in my truck Quote Link to comment
ggzilla Posted April 29, 2009 Report Share Posted April 29, 2009 Yes, but the 35A also has plenty of juice to keep a gel cell running... so what is the point of fitting a 50A? Quote Link to comment
Farmer Joe Posted April 29, 2009 Report Share Posted April 29, 2009 Yes, but the 35A also has plenty of juice to keep a gel cell running... so what is the point of fitting a 50A? prolly for a stereo system or the air compressors. Quote Link to comment
ggzilla Posted April 29, 2009 Report Share Posted April 29, 2009 For that you should go for the 90A Quote Link to comment
oldsklminitrk Posted April 29, 2009 Author Report Share Posted April 29, 2009 prolly for a stereo system or the air compressors. Yeah when my compressor kicks on with the stereo on the volts drop to about 10.5 volts now with this I can have the lights on the stereo playing and the compressor running and it wont drop below 12.2 volts. Quote Link to comment
