DatDoug Posted April 27, 2009 Report Share Posted April 27, 2009 OK I should know this! The breather tube on top of the valve cover, does it SUCK or does it BLOW??:blink: Quote Link to comment
N0RCALDIME Posted April 27, 2009 Report Share Posted April 27, 2009 it "blows" outward. but sexually, those terms mean the same... :) Quote Link to comment
Wharf Rat Posted April 27, 2009 Report Share Posted April 27, 2009 And if it blows hard your rings are pooched, as in blow by. In the other it means loose lips :blink: Quote Link to comment
N0RCALDIME Posted April 28, 2009 Report Share Posted April 28, 2009 And if it blows hard your rings are pooched, as in blow by. In the other it means loose lips :blink: how hard is hard? Quote Link to comment
Wharf Rat Posted April 28, 2009 Report Share Posted April 28, 2009 Ha Ha well if theres smoke coming out with it the rings are gone or the lips are on fire :) Quote Link to comment
datzenmike Posted April 28, 2009 Report Share Posted April 28, 2009 OK I should know this! The breather tube on top of the valve cover, does it SUCK or does it BLOW??:blink: It normally, 99.9% of the time, allows air IN to replace combustion and water vapor that is drawn past the PCV valve into the intake by intake vacuum. In rare cases of heavy throttle or worn rings the blow-by exceeds the PCV valve's ability to draw it in and flow reverses OUT the valve cover breather. If it blows that sucks. Quote Link to comment
Wharf Rat Posted April 28, 2009 Report Share Posted April 28, 2009 Man there I go again not even thinking of the PCV valve on newer but still old cars. A very light suck is a good thing. My head is in the gutter ...... sorry:blink: Quote Link to comment
odmanjohnson Posted May 4, 2009 Report Share Posted May 4, 2009 "Mega-Maid sir, shes gone from suck to blow!" Quote Link to comment
