ronnie93212 Posted March 22, 2009 Author Report Share Posted March 22, 2009 like 15 min away from tulare Link to comment
650savag Posted March 23, 2009 Report Share Posted March 23, 2009 What shape is the steering wheel? Price shipped to 27401? Thanks I did a search on steering wheel removal and came up with one good thread. It basically says to remove the horn button, remove the nut and washers, and then use a puller or you can use the palm of your hads to bumb it off from the back side. Be careful when you do this because it could fly off and hit you in the face! Hope this helps you get the wheel off. Link to comment
BarryA Posted March 23, 2009 Report Share Posted March 23, 2009 column is black and does NOT have the big hole in the bottom for the steering column adjuster lever (and isn't cracked or otherwise trashed), I'm interested - I need a decent one for an early 2wd. Link to comment
ronnie93212 Posted March 23, 2009 Author Report Share Posted March 23, 2009 no its blue sorry but its good condition Link to comment
ronnie93212 Posted March 23, 2009 Author Report Share Posted March 23, 2009 I did a search on steering wheel removal and came up with one good thread. It basically says to remove the horn button, remove the nut and washers, and then use a puller or you can use the palm of your hads to bumb it off from the back side. Be careful when you do this because it could fly off and hit you in the face! Hope this helps you get the wheel off. and ill try that Link to comment
OneFreakyMF Posted June 7, 2009 Report Share Posted June 7, 2009 wouldnt still happen to have the front axle shafts would ya?? Link to comment
