sdsurf Posted March 21, 2009 Report Share Posted March 21, 2009 Ok I have a Z20 for sale that is complete carb to exhaust. I was told it has good compression $175 Trans not included... Link to comment
datzenmike Posted March 21, 2009 Report Share Posted March 21, 2009 Ah, an HLA10 motor. Any chance of a good picture of the tranny?:D Link to comment
sdsurf Posted March 21, 2009 Author Report Share Posted March 21, 2009 I am going to keep the tranny. Original for the truck Link to comment
datzenmike Posted March 21, 2009 Report Share Posted March 21, 2009 You will need a splined output shaft for the front of your driveshaft in order to use it. So, no picture of the tranny? Link to comment
datsunaholic Posted March 21, 2009 Report Share Posted March 21, 2009 Actually that looks like a 521 trans bolted to a Z20. Not a A10 trans. Too much waffling for the F4W63L. Link to comment
ronnie93212 Posted March 21, 2009 Report Share Posted March 21, 2009 do u know if the trans from my 78 620 datsun would direct bolt onto that z20 engine? Link to comment
datzenmike Posted March 21, 2009 Report Share Posted March 21, 2009 Doug, if we had a picture of it, (HINT,HINT) we could see if it has the flange output on it. I'm going with the F4W63 with Z bolt pattern because the starter would be closer to the block if it was an L pattern and the tailstock has two switches at least. I think the 521 only had reverse switch. Plus it just looks oriented right for a Z engine. Link to comment
datzenmike Posted March 21, 2009 Report Share Posted March 21, 2009 do u know if the trans from my 78 620 datsun would direct bolt onto that z20 engine? Yes, both blocks are almost identical so it will bolt up to a Z engine. The problem... there's always a problem... is that the Z engine sits almost straight up and down while the L series engine is tilted on it's right side by about 12 degrees. This means that your '78 L tranny will have to be rotated about 12 degrees to the left side to mate to the Z engine bolt holes. The shifter will also rotate over much closer to your right knee. Additionally, the tranny mount will also not sit flat on the rubber mount. Having never done or seen this, I don't know how bad this tilt toward the driver is. You may be able to just put a small bend in the shift lever above the mounting pin to place it upright. A small wedge or shim could be placed under the tranny mount. Link to comment
datsunaholic Posted March 22, 2009 Report Share Posted March 22, 2009 The 521 had 2 switches- one for reverse, and a top-gear switch for the dual-points. Link to comment
sdsurf Posted March 23, 2009 Author Report Share Posted March 23, 2009 Whatever the transmission stock for a 521 (i forget the number) is, is this trans. I will get pics up tomorrow when it gets light. Link to comment
sdsurf Posted March 23, 2009 Author Report Share Posted March 23, 2009 alright here they are you may now solve the mysteries... Link to comment
sdsurf Posted March 23, 2009 Author Report Share Posted March 23, 2009 Yes, both blocks are almost identical so it will bolt up to a Z engine. The problem... there's always a problem... is that the Z engine sits almost straight up and down while the L series engine is tilted on it's right side by about 12 degrees. This means that your '78 L tranny will have to be rotated about 12 degrees to the left side to mate to the Z engine bolt holes. The shifter will also rotate over much closer to your right knee. Additionally, the tranny mount will also not sit flat on the rubber mount. Having never done or seen this, I don't know how bad this tilt toward the driver is. You may be able to just put a small bend in the shift lever above the mounting pin to place it upright. A small wedge or shim could be placed under the tranny mount. if you look at the pics in my build thread you may see the tilt. Mike was right. The angle is worng. The shifter was slammed to the left and the carb wasn't level Link to comment
datzenmike Posted March 23, 2009 Report Share Posted March 23, 2009 (edited) Definitely an L series tranny! Flange output makes it an F4W63 from a 520/521. You were right Doug. Weren't these also used in the first few months of 620 production up until Sept '73? Edited March 23, 2009 by datzenmike Link to comment
datsunaholic Posted March 23, 2009 Report Share Posted March 23, 2009 The F4W63 was used in the '72-73 620, but didn't have the flanged output. Had the normal spline-sleeve. Link to comment
sdsurf Posted March 24, 2009 Author Report Share Posted March 24, 2009 engine still for sale $175! Link to comment
