philip1 Posted March 15, 2009 Report Share Posted March 15, 2009 will a Pl510 bar fit an HL510? I have one for a PL. Quote Link to comment
datzenmike Posted March 15, 2009 Report Share Posted March 15, 2009 Unlikely, the PL has IRS and the HL is a solid axle. Quote Link to comment
freaky510 Posted March 15, 2009 Report Share Posted March 15, 2009 are you refering to a front or rear bar. front yes with a little mod i belive and a rear you wouldnt need one. imo you would get better results with a pan hard STYLE bar so keep the rear more riged in cornering just $.02 Quote Link to comment
datzenmike Posted March 15, 2009 Report Share Posted March 15, 2009 :o Don't know why I assumed it was rear. The pt. #s for the HL 510 front are: 54611 W5000 sedan 54611 W5400 wagon Quote Link to comment
philip1 Posted March 16, 2009 Author Report Share Posted March 16, 2009 I was talking about the front bar .... I will just have to try the PL bar out to see if it will fit. I think a rear bar configuration similar to what the camaro uses will work best. that being a sway bar pivoted at the axle and the endlinks mounting to the body/frame. As far as a panhard bar, it is not necessary since the angled upper links locate the axle side to side. Quote Link to comment
