spottedog Posted March 3, 2009 Report Share Posted March 3, 2009 (edited) Do I use L20B timing chain guides on the Z24 block? (I wish I had taken notes when I put this thing together the first time!) :) Edited March 3, 2009 by datzenmike Quote Link to comment
datzenmike Posted March 3, 2009 Report Share Posted March 3, 2009 The Z24 block is 2cm taller than the L20B, presumably the guides are too. If you have them I would use them. Probably not the end of the world if L20B were used. Quote Link to comment
spottedog Posted March 3, 2009 Author Report Share Posted March 3, 2009 The Z24 block is 2cm taller than the L20B, presumably the guides are too. If you have them I would use them. Probably not the end of the world if L20B were used. Actually, the L20b chain guides are longer than the Z24 guides! :confused: (The tension side guide is almost 2" longer than the Z24 guide) Quote Link to comment
datzenmike Posted March 3, 2009 Report Share Posted March 3, 2009 Well I presumed wrong. The Z cam sits lower than the L head cam and I think the head is thinner top to bottom so this does make sense. Quote Link to comment
spottedog Posted March 3, 2009 Author Report Share Posted March 3, 2009 Well I presumed wrong. The Z cam sits lower than the L head cam and I think the head is thinner top to bottom so this does make sense. I would not have guessed. But, any day we don't learn something new ain't much of a day. ;) Carquest has been real good about having any part on the counter the next morning, so I will bolt it up and see what it looks like. Quote Link to comment
hang_510 Posted March 3, 2009 Report Share Posted March 3, 2009 what chain are you using? i was gonna replace the Z24 guides w/ L20 next time. havent looked to confirm fitment, so you may have saved me some headache :cool: Quote Link to comment
