R16 Carburator
Partnumber: 1129
1600 SU High Flow Re-usable Air Cleaner Assembly Can be purchased with or without velocity stacks. Price is for air cleaner, drilled back plate and gaskets only. Now 1600 owners can increase their breathing.Note: There is no provision in the back plate for PCV hose mounting. There are after market pcv filters that can be attached to your valve cover breather outlet. Venting directly into the air filter can damage the assembly.
$199.00
R16 Carburator
Partnumber: 1129
$199.00
R16 Carburator
Partnumber: 1129
1600 SU High Flow Re-usable Air Cleaner Assembly Can be purchased with or without velocity stacks. Price is for air cleaner, drilled back plate and gaskets only. Now 160 owners can increase their breathing.Note: There is no provision in the back plate for PCV hose mounting. There are after market pcv filters that can be attached to your valve cover breather outlet. Venting directly into the air filter can damage the assembly.
$199.00
