Labubre
92 -
Content Type
Profiles
Forums
Events
Store
Classifieds
Everything posted by Labubre
Did you fix it finally? Mine was creating problem and stopping the engine from time to time. Got me nuts! Once disconnected, no more engine issue So looking for a replacement one!!! If anyone has one for sale or a plan to get it replaced. THX!
Damn it! did not want to be rude or offend anybody here..."damn it" in french is far from being unpolite. But Ok, french baseline...
Kayaba 665012 for front? (pending delivery) Took KYB 343149 for the rear Not a wagon but a SSS coupe
anybody? need it too approx 12.6 x 5.9 x 2.36 or 320x150x60mm
Hi, Have an oval air filter on my 510 sss dimensions: 12.6 x 5.9 x 2.36" Anybody knows an altrenate reference Can't find any! Thx Seb
did you fix it finally?
End of story...seat belt mount hole drilled through the wire....bad luck! Everything back to normal
Thanks, will try to figure this out next time i visit car underneath. Perhaps a reference will be mentionned
That the feedback from my friend that is a mechanic and former nissan dealer in th 80's He also did a "race" start and from the way rear wheel entered in motion he also told me so He also check that once the car lifted up Perhaps a sss option?
If LSD is stock, what oil should i use?
Hi! Seems to me that i have a LSD diff on my european 1600 sss Is this stock or part of the legacy of its portuguese origins and rebuild... Is this differential specific or can be found on other datsuns? Thx Seb
Hi, Talking about the 2 wires one, 3 wires easilly found on RAuto. Would any of these fit? Echlin LS6255 ACDelco 88863476 ACDelco LS278 BWD PT294 Chrysler PT294 Duralast 893 Airtex 1P1525 Dorman 84808 Import Direct 40-0101 BWD Intermotor PT294 CARQUEST Premium By WELLS 57-5306 Carquest Premium Vehicle Solutions PTA1309 Thanks Seb
Have the Hitachi D409-54K inside, single contact Was looking for parts change: - rotor - contact points - distributor cap Is this distributor specific to the sss, can i go with standard 510 parts? Thanks
Finally ordered at amayama.com for 60$ including delivery to France Will confirm all is OK after install
found on aussie forum nissan reference 16061-K1407 also reported to be same ref for roadster 2000 as found on 311s.org ztherapy also sells the same part code for regular 510, 510sss and 2000 roadster (hjl-38W) so i feel like this is a good one available on nissanpartsdeal.com and amayama.com (i do not know this site)
Anybody know where to source floaters for this carb? Or interchange part? Did not find the PCV hose yet as finally there was a mistake on nissanpart.online site. Thx Seb
Hi, Helping a crazy datsun/nissan owner and former dealers in the 80's to find parts for one of his 15? 16? cars (or more...) Not sure this has been sold in US but taking my chance here as can hardly find info from the internet. Looking for front/rear struts as a start. Anybody know what strut model/alternative could fit? Thanks Seb
Finally ordered Through ARP. Found the Nissan part code since then 12109-N0100 Bolt Connecting Rod (TOKAI). Bolt Connector Rod. Part Number: 12109-N0100 Supersession(s): 11810-N0110; 11828-N0110; 12109-A3502; 12109-N0110; 12109N0100; 12112-N0100 Waiting... https://parts.royalmotornissan.com/p/Bolt-Connecting-Rod-TOKAI-Bolt-Connector-Rod/89402579/12109-N0100.html
Here's my source 4.5-5.5Kgm / 33-40lb-lb
That's a very good info. Thanks Mike! For the tightening torque I will double check.
