debbheff@gmail.com
52 -
Content Type
Profiles
Forums
Events
Store
Classifieds
Everything posted by debbheff@gmail.com
Lots to do, i didnt adjust shoes then stab the brake pedal to center the adjuster and continue adjusting. I'll try that next. additionally i bled the mc on the vehicle but did it with the pushrod attached to the pedal arm. will detach the pushrod from pedal arm and do over. incidently i did bench bleed the mc in a vise with a hose and tube back to the resevoir. I did have to cut the pedal arm as mklotz77 indicated so that necessitated removing the mc once more. As an aside, my wifey was helping me bleed the system, i was at the pass side rear and had already bled the system into a bleed jar so she was going to get best pedal and i was going to crack the bleeder to make sure air was out of the system. we did one pass at right rear and told her get the best pedal while i cracked the bleeder one last time. she pumped it up, and before i could crack the bleeder i heard the pedal hit the floor and all the brake fluid exited the long line from the diverter through a hole in the line an onto the floor. This of course left absolutely no brakes at all on any corner. i was really glad that line popped when it did, i could see running up on a vehicle, stop sign or whatever ,hitting the brake and nothing there, and with a single mc system the sequence of events would not end well. all this prompted me to replace the hard lines and i just bought a roll of nicu and worked from that. that stuff works well and flares with a standard flaring tool commonly available as a rental from parts stores. just be aware, if you're tooling around in a single mc version of the 520/521 or early 620 and havnt replaced the hard lines particularly the long line from the diverter to the rear brakes and the brake hoses, you're living on borrowed time. when those lines go they go in a way that gets you looking for a soft place to land and often there aint one.
I've read several of the posts on brakes here on the forum and still have a question about brake adjustment on my 521. I installed all most brake components new from the master cylinder down to the new shoes with exception of rear brake springs and front hard brake lines. up to this point i've bench bled the master cylinder at least three time and the wheel cylinders more than that. i've adjusted the brakes to a light drag and still i cannot get a good hard pedal. initially the pedal feels good just sitting in the truck but when driven it takes some effort to get the truk to stop and the pedal goes almost to the floor. At this point i'm beginning to suspect i have a bad "new" brake master cylinder but the one thing i didnt do was to adjust the shoes as described in one of the posts i.e. adjust till hard to turn wheel step on brake hard and if the wheel can still be turned adjust some more , etc. Is this important or is one try to adjust till hard to turn sufficient. Its been a long time since i drove a vehicle with 4 wheel drums so i dont remember how good(bad) these things are supposed to be.
Thanks for letting me know you have the parts, I think i have all the pins and springs i need just need the clips. Thanks again
A bit of research and i found spring attachment clips at napa, believe these will work if i can find a place to clip them. Thanks
When i bought the truck both clutch and brake pedals were on the floor. I've installed new clutch master and brake master cylinders but cannot figure out where to connect the return spring for the brake pedal . my repair manual shows a 521 pedal assembly with spring attached at a point on the pedal moiunt connection pin but no detail where it attaches to the body. any help on where to connect the spring appreciated Thanks
any leads on rear brake hose part number, a good source for the hose etc. ordered one from local parts and it looked correct but wrong male thread for the brass distribution union. Thanks DH
try moss motor sports, select shop by model select the 100, 100-6, 3000 from left side menu select suspension then front suspension. i purchased the fulcrum pin part 65 and it is a direct replacement for the datsun fulcrum pin (for my 521). the other parts associated with the fulcrum pin may work also they appear to be the same or similar.
Try moss motor sports. once at the site select shop by model and select the big healy's 100, 100-6, 3000. left menu select suspension then front suspension, part number 52 is the cotter bolt and i believe it will work, no guarantees because i havnt tried that part. i did buy the fulcrum pin part 65 and it is a direct replacement for the datsun fulcrum pin. i suspect the other parts 68 and 70 and the seals 69 will work also.
continuing, i've started it a couple of time and no smoking although run time was seconds. still sorting out coolant and heater hoses and still havnt got fuel tank back from shop. on to other things front brakes redone as well as new fulcrum pins, did i mention i discovered the big Healy fulcrum pins are the same as the Datsun pins. good info for anyone searching for pins, and cheap also, relatively speaking that is.
yeh finally figured out the bajno end is a separate piece and found the hoses at local parts store.
Yeh, seems like the 521 forum is working out, great folks and lots of good info.
As it turns out, i looked at the end of the banjo fitting and sure enough the end of the hose had a hex end that appeared to be removable. after application of freeall and heat the hose end detached from the banjo end. looks like those hoses indicated to fit the 521 do actually work. thanks again DH
yep this piece has been put together so it cant be disassembled. I'll look for a suitable replacement that can be fitted without stacking washers etc. anyone out there with knowledge of a good replacement let me know.
Checked my Chilton Foreign Car Repair Manual, French, British, Japanese Cars, vol II and it shows similar setup as mine, the hollow bolt is referred to as a connector bolt. In Chilton this particular application is for a 520, the 521 although the model is included in this manual.
on this truck there is the banjo fitting at the end of the brake hose, a hollow bolt to carry brake fluid hat fits thru the banjo and threads into the wheel cylinder. the bolt has an open end where the bleeder screw fits. a sort of mdcf of a setup but it apparently worked except for the part where parts are nla.
Here we go again, this time front brake hoses. Again, i've done numerous searches and can't find the right brake hoses for the front. I find all sorts of hoses that indicate they are for the front of a 521 but none have the correct banjo fitting that attaches to the wheel cylinder. It had been a while since i had taken the fronts apart so i bought hoses I thought would fit and started installing them and saw there would be no place to bleed the brakes. Found my old wheel cylinders and hoses and discovered the fitting attached to the wheel cylinder is some funky looking banjo fitting with the bleed screw attached bolt that holds it to wheel cylinder. I searched thru hoses at my local parts dealer and came up with a hose with a banjo end that appeared to maybe work but it would require stacking three copper seals to get the distance required for the brake fluid holes to line up. So, does anyone know where to get the correct banjo end brake hoses OR what have you done to come up with a workable alternative. Thanks as always DH
Thanks, that's about what i thought, nla. I know someone who works at a parts store so i can likely look thru their hoses and come up with some suitable substitutes. Thanks again
does anyone have a good source for coolant hoses for my 521. i can get upper and lower radiator hoses from O'Reilly's but no matter what search strings i use i cant seem to come up with a source(s) for the smaller molded heater and bypass hoses. any source information appreciated (I havnt contacted the local nissan dealer, yet) Thanks DH
Time Left: 2 days and 20 hours
- WANTED
- USED
I need a top part generally shown as carburetor in parts diagrams, for a weber 32 36 carb. the choke shaft bores in mine are worn and not repairable. will consider buying a parts carb but would prefer just the top if you have one available. Thanks DHAsk for price
Looks like all the numbers match. 1 number 1, 3 number 3's
good point carbon build up on ring lands and rings. guess that settles it, out she comes. btw, i had shop replace the broken guide, reseated the all valves just to make sure any carbon was addressed, new nissan seals installed, machinist went over the valves and indicated all the stems were within spec and guides were in good serviceable condition. Head is ready to go, now on to the block.
lots to think about, i've considered whoever put it together didnt know what they were doing. going to put it together to see what happens next. hopefully all will be good and it starts and runs.
Thats about it, no valve sealing as intended thru use of valve seals at least on the broken guide at number 4 exhaust, number four exhibited heavy oiling all the others exhibited typical oiling of intake and exhaust runners like you would expect if the valve seals were worn out, in this case the seals were the wrong seal, too big so pulled oil past the seals. on number four the seal remained on the broken part of the guide. when i was pulling the seals off the guides, number four practically fell out in my fingers and thought hmmmm, thats odd came off to easy, then looked at seal and saw the end of the broken guide and thought hmmm not good, no sir not good at all. So if you had to hazard a guess, would you expect the broken guide and the low compression number to be related?
More info, no bent valves, no evidence the valve spring retainer hit the guide on number 4.
