So then my diodes are probably bad because they drain my battery ? It didn’t use to do this before even after the ka swap. Everything is still wired the same. If after removing the sense and light goes off that stops the drain once plugged in the diodes drain it. Are the diodes grounding out or something? Reason my test light goes on with any metal
