rbastedo Posted January 20, 2009 Report Share Posted January 20, 2009 I put on the manual choke conversion kit a while back and when I did I left all the auto choke equipment alone if it wasn't in the way of the manual setup. Now I'd like to clean it up a bit by removing things that don't need to be there, only I'm not sure what's needed and what's not. Help? :confused: Quote Link to comment
ggzilla Posted January 21, 2009 Report Share Posted January 21, 2009 That's a tough question. You can unbolt the choke housing, and remove all the diaphragm stuff, but the linkage ties into it. I don't know exactly how it would work out. Quote Link to comment
rbastedo Posted January 21, 2009 Author Report Share Posted January 21, 2009 That diaphragm that hooks up to the choke shaft was causing some interference so I pulled the pin that connected it. That freed it up a bit and led me to think there might be other stuff I could get rid of. Quote Link to comment
