seannn Posted April 26 Report Share Posted April 26 Hello I was having some problems with the hazards they didn't work when I looked at it, it didn't have the the plug well it was connected but the female side of the plug didn't have any wires only the plastic. Does anyone have any idea how to wire the 5 pin hazard? Quote Link to comment
datzenmike Posted April 26 Report Share Posted April 26 Which is the female side? Harness or switch side? Quote Link to comment
seannn Posted April 27 Author Report Share Posted April 27 Harness side. It was connected to the switch plug but the harness plug was only the plastic no wires. Quote Link to comment
datzenmike Posted April 27 Report Share Posted April 27 Well the wires must till be nearby. The connector on the hazard switch side has 6 positions but only uses 5 of them. Two rows of three. match it to the harness. You'll have to figure out if this is upside down or left to right by looking at the switch plug end. Blank.................. Red/Blue Green/Black....... Green/White Green/Red.......... Green Quote Link to comment
seannn Posted April 27 Author Report Share Posted April 27 I was looking for the wires and they are no wires I am not sure if they were removed by someone. Do you know what each color wire from the switch is from. I have no idea how the switch wires work. Quote Link to comment
Seven Two Oh No Posted April 27 Report Share Posted April 27 I can send you some pages from the 84 factory service manual that has most of the switch wiring diagrams. Check your DMs 1 Quote Link to comment
seannn Posted April 27 Author Report Share Posted April 27 1 hour ago, Seven Two Oh No said: I can send you some pages from the 84 factory service manual that has most of the switch wiring diagrams. Check your DMs Thank you very much I would really appreciate it! Quote Link to comment
