Hazard switch
seannn
Hello I was having some problems with the hazards they didn't work when I looked at it, it didn't have the the plug well it was connected but the female side of the plug didn't have any wires only the plastic. Does anyone have any idea how to wire the 5 pin hazard?
  • Replies 6
Well the wires must till be nearby.
The connector on the hazard switch side has 6 positions but only uses 5 of them. Two rows of three. match it to the harness.
You'll have to figure out if this is upside down or left to right by looking at the switch plug end.
Blank.................. Red/Blue
Green/Black....... Green/White
Green/Red.......... Green
I was looking for the wires and they are no wires I am not sure if they were removed by someone. Do you know what each color wire from the switch is from. I have no idea how the switch wires work.
1 hour ago, Seven Two Oh No said:
I can send you some pages from the 84 factory service manual that has most of the switch wiring diagrams. Check your DMs
Thank you very much I would really appreciate it!
