edwardsjethro Posted March 28 Report Share Posted March 28 Hi guys I've done reading on as many sights as possible but I cant quite seem to find exactly what it is im looking for I have a distributor from a 1984 z24 And im looking to mount it onto my z24i because im going turbo and fitech. All I want to know is what else do I need to make it all fit together from what it looks like ill need to swap to a different timing cover to make the mounting correct also the distributor doesn't seem to seal at all with my current timing cover so if anyone has any info on this topic a response would be very much appreciated thank you so much. Quote Link to comment
datzenmike Posted March 28 Report Share Posted March 28 The Z24i timing cover is the same for all Z24 and Z24i engines. Even the D21 Hardbody Z24i The earlier Z24 distributor has a pedestal on the bottom that actually bolts to the timing cover. They look similar to these... Quote Link to comment
