RafaelSagrero Posted March 14 Report Share Posted March 14 Good evening friends, yesterday I was driving my Nissan 720 at 40mph, suddenly on an inclined straightaway it began to choke for a few seconds (it hasn't done it again) and released a couple of explosions from the exhaust. After 5 minutes smoke started coming out of the hood and I thought it was overheating but the coolant was ok in the radiator and the temperature was 80°C. I saw that smoke was coming out of the oil dipstick and when I removed the cap more smoke came out. I checked the compression and cylinder 1-2-3 has more than 160psi and cylinder 4 has 110psi, what could be the fault, my engine was running perfectly and suddenly it fails like this. It shakes at low revs but above 1200-1500 it runs almost perfect. A month ago they changed the complete distribution and valve seals. What could it be, my mechanic says it needs to be ringed? Quote Link to comment
datzenmike Posted March 14 Report Share Posted March 14 Try the compression again on #4 then a second time with a few teaspoons full of engine oil. If not much change it not the rings. If it goes up 5 -10 PSI then the rings are nor sealing. See what you get. Quote Link to comment
