nathan.is.an.idiot12312 Posted February 7 Report Share Posted February 7 so this morning when i was about to leave i fired up my datsun and it ran fine and then before i could even bring it down from high rpms it stalled out and would not fire up again. i do not think its getting any gas anymore i run a weber 32/36, i just recently replaced the crankshaft fuel pump, it ran and drove perfectly last night, is this a filter problem? i have a lot of debris in the tank? please help, i daily drive this car and i need it running Quote Link to comment
datzenmike Posted February 7 Report Share Posted February 7 When there is a failure that is unexpected look back to what you have done recently. You replaced the fuel pump? Good place to start unless the reason for replacing it is the same problem you have now in which case you have a different problem that the pump. So, why was the pump replaced? What was it doing/not doing? Quote Link to comment
nathan.is.an.idiot12312 Posted February 7 Author Report Share Posted February 7 the pump was replaces well.. because it stopped pumping gas, it pumped gas fine as soon as i replaced it though, the lines are dry, ill disconnect the hoses and have my dad turn the starter to see if im getting suction. Quote Link to comment
datzenmike Posted February 7 Report Share Posted February 7 Seems unlikely that two pumps would be bad. Direct the outlet into a container, disconnect the coil and crank with starter. Got gas? YES..... carburetor float stuck in up position, needle valve or screen plugged on carburetor. NO....... Supply fuel to the inlet of the pump from a container, turn engine with starter. Gas??? YES.... tank is empty or fuel line plugged or kinked. possibly loose hose clamp on tank side letting air in pump can't lift the gas. NO.... pump not working due to damaged cam eccentric. Quote Link to comment
nathan.is.an.idiot12312 Posted February 8 Author Report Share Posted February 8 i got it figured out. my fuel filter completely choked the line. i have a lot of sediment in the tank. i need to drain and drop it soon. thanks for the help and fast responses Quote Link to comment
datzenmike Posted February 8 Report Share Posted February 8 Buy a couple of filters. When I got my 710 I made it 20 miles before it quit. I disconnected the tank side and just shook it and the gas inside rinsed the rust out and got me going. Did it one more time about 20 miles later and by 20 more miles I was home. Emptied the gas and collected this... Took the delicate sender out and put 3 double handfulls of (relatively) clean driveway graves in and rolled it around on the lawn. Dumped it out and hosed it clean. Left in the hot sun to dry the interior. Filtered the orange/brown gas through a filter and reused it. I mean.... Datsun owner, right???? New filter and never had a problem after that. 1 Quote Link to comment
