Jason hughes Posted February 4 Report Share Posted February 4 Hi help needed to ID which gearbox and if there are any replacement 3rd gear synchro ring and outer hub gearbox has stamping 2 26 93 are there synchros available it is a steel type ring in the 3rd gear and 3rd to 4th outer hub required any advice would be appreciated kind regards Quote Link to comment
datzenmike Posted February 4 Report Share Posted February 4 We didn't get a five speed in N America for the second generation Z car till '77, but Europe did. The removable bell from the earlier Fairlady Roadster SRL311 was cast in an L series configuration moving the starter and engine lean to the right side and used on the next generation 240Z. Does your transmission look like this?... FS5C71A (this one is an L series with starter on the right) Left to right: tail or rear case, thin adapter plate, front case, removable bell housing. Below, drive shaft bolts onto transmission flange rather than being pushed into rear case It would appear that 1st/2nd and 3rd/4th synchronizer rings and hubs are the same. Synchronizer ring.............. 32611-14600 Synchronizer hub.............. 32601-14600 In North America Roadster transmission parts are as rare as hen's teeth. Often said they are made of un-obtanium. You may have better luck where you are? Quote Link to comment
