Dat_Cali_Mike Posted February 1 Report Share Posted February 1 I'm looking to upgrade my trans to a 5 speed. but not sure if what Trans will work. Is it possible to use a z car trans? Quote Link to comment
datzenmike Posted February 1 Report Share Posted February 1 Ask yourself do you drive primarily in town or highway. If in town a 5 speed won't get much use. Just saying... A Z car 5 speed will work but there are lots of others. All L series 4 or 6 cylinders can share their transmissions. (though some are not advised) Your '77 4 speed is a 71B transmission the 5 speed is also a 71B so physically identical and will fit without any mods. What ever 5 speed you get make sure you use your clutch 4 speed release bearing collar, it's intimately matched to your pressure plate. The 5 speed may come with it's own collar but no telling what clutch it's mated to so use the one from the 4 speed. '77-'78 280z mid ratio '79 280zx mid ratio '80-'83 non turbo 280zx close ratio '77-'78 620 mid ratio '79 620 wide ratio '78-'84 810/Maxima gas engine mid ratio '80 720 2wd wide ratio Personally I wouldn't use the close ratio in a heavy truck, just my opinion. If you live in town it has a very high over drive and would get even less use. The mid ratio is perfect and what the '77 had optionally. The wide ratio is also good. You may find that a 280z and early 280zx Z car 5 speed commands a higher price, because Z car! Be assured that the other mid ratio 5 speeds are identical. Quote Link to comment
IZRL Posted February 1 Report Share Posted February 1 (edited) Edit: I had a question about this topic but I found the answer. Disregard Edited February 1 by IZRL Quote Link to comment
Dat_Cali_Mike Posted February 1 Author Report Share Posted February 1 That explains it all, thank you Mike. Quote Link to comment
