datsun229 Posted October 5, 2023 Report Share Posted October 5, 2023 Can someone show me where the distributor points for l20b Quote Link to comment
datzenmike Posted October 5, 2023 Report Share Posted October 5, 2023 Set engine to TDC compression stroke on number one cylinder using the notch on the crankshaft pulley and the ignition timing scale on the 0 mark. Lift out the distributor and look in the hole. You should see this... If you have this put the distributor back in and the rotor should point to one of the plug wires on the distributor cap. This is number one and the firing order is 1, 3, 4, 2 in a counter clockwise direction. If you don't have the 11:28 as in the picture above let me know. Quote Link to comment
datsun229 Posted October 5, 2023 Author Report Share Posted October 5, 2023 Ok I have it at 11:28 can you show me the fireing order Quote Link to comment
Dusten Posted October 5, 2023 Report Share Posted October 5, 2023 4 hours ago, datsun229 said: Ok I have it at 11:28 can you show me the fireing order 2 Quote Link to comment
