Fuel Filler Leak
johnsontf
When I fill my tank and fuel creeps up the fill hose to shut off the pump, I get leaks coming from where the filled hose meets the top of the tank. It leaks a lot for a moment then stops. This makes me think there is a leak in either the breather hose area or the fill hose. Are either a common issue? I am trying to track it down but I can only see when its actively leaking, then fuel dries up and I can't see where its coming from.
  • Replies 1
