datsun229 Posted August 23, 2023 Report Share Posted August 23, 2023 Does anybody have a l18b flexplate 5bolt pattern Quote Link to comment
datzenmike Posted August 23, 2023 Report Share Posted August 23, 2023 L16s also use the same 3N71B flexplate. Is the starter ring worn out? Quote Link to comment
datsun229 Posted August 23, 2023 Author Report Share Posted August 23, 2023 The flexplate is gear is worn out Quote Link to comment
datzenmike Posted August 23, 2023 Report Share Posted August 23, 2023 Well you could zip cut the welds and take the ring gear off, turn it around and tack it back on or have someone do this.. Any L16/18/L20B manual flywheel or automatic flexplate after '71 use the same ring gear. Manual flywheels you can just tap them off. The dealer may still have them? about $100. Quote Link to comment
datsun229 Posted August 23, 2023 Author Report Share Posted August 23, 2023 Can the l3n71b automatic transmission bolt up to the napz motor Quote Link to comment
datzenmike Posted August 23, 2023 Report Share Posted August 23, 2023 Yes the 720 automatics were 3N71Bs but it must have a Z series bell housing that matches the Z series engine. In other words the 3N71B for an L20B that was in a 620 will bolt up but won't work. But you could take the L series bell housing off and swap a Z series one on. There were two 3N71Bs used in the 720. The early were like previous, but the '83 and on had locking torque converters. The torque converter, flex plate and bell housing plus interior parts were different. Quote Link to comment
datsun229 Posted August 23, 2023 Author Report Share Posted August 23, 2023 Do you know anyone who has a napz bell housing Quote Link to comment
datzenmike Posted August 23, 2023 Report Share Posted August 23, 2023 What about your flex plate? Put your year 720 in your profile, saves asking multiple questions. Quote Link to comment
datsun229 Posted August 25, 2023 Author Report Share Posted August 25, 2023 Do you have one for sale a flexplate 5 bolt pattern Quote Link to comment
