LigerZero89 Posted August 17, 2023 Report Share Posted August 17, 2023 I have a question. I’ve been searching all over the forum and I haven’t been able to find a concrete answer anywhere. What all do I have to do to install drop spindles on a 720?.. I have an 84 rwd 720. It needs wheel bearings. I’ve also been wanting to lower it, so I figured now would be the perfect time to do it all. What all would I need to install drop spindles? If someone could give me a list of what I’ll need, and any tips, I would appreciate it!! Quote Link to comment
thisismatt Posted August 17, 2023 Report Share Posted August 17, 2023 Pretty sure you just get the kit and new bearings & seals while you're at it. Need to cut outer tie rod ends a bit to get the toe back into alignment. Here are the instructions that detail everything https://www.belltech.com/extras/docs/BBGC/2005-888.pdf Quote Link to comment
LigerZero89 Posted August 17, 2023 Author Report Share Posted August 17, 2023 Thank you…. I had seen in another thread that someone recommended swapping the upper and lower control arms off a D21 and using the drop spindles. However, like I had said, there’s no confirming wether said person did that or not, and no one has confirmed wether that would work. I would love to replace everything with new suspension, and if the D21 front suspension works, why not? It would probably make things easier in the long run. Plus I’d like to change over to D21 calipers and rotors….. if it fits without modifying. Quote Link to comment
thisismatt Posted August 17, 2023 Report Share Posted August 17, 2023 Pretty sure you can do that as obviously the spindles work with both. Iirc there are some thick washers you have to use on the caliper ears for the 720 calipers. I own all the parts, with the intention of using them on my 521, just never have the time. Quote Link to comment
LigerZero89 Posted August 17, 2023 Author Report Share Posted August 17, 2023 I appreciate it! Quote Link to comment
