Reverse light issue (there isn't one...)
DanDatsun
Hey all. The guy who owned the truck before me disconnected the reverse gear wire from the gearbox - it looks like should be a plug in connector straight into the outer casing of the gearbox... all that is left is the remains of the connector. Anyone have to fix this issue before and know what part reference that would be? Thanks.
  • Replies 1
Does the switch still work?
Easiest solution if not working is just replace it.. in another thread we looked up the switch for these 63 series 4spds and the 71b transmissions .... turns out they can both be found at the dealership still... or online parts store....
https://www.nissanpartsdeal.com/parts/nissan-switch-rev-lamp~32005-21101.html
The number can be cross referenced at ...
https://www.carpartsmanual.com/datsun/pickup-1965-1972/power-train/transmission-case/from-oct-65
