IronFromIce Posted July 28, 2023 Report Share Posted July 28, 2023 Hey Everybody, new forum user and 720 newb here. Just got an '86 720 4x4 from a buddy and as i started poking around i noticed the oil pan looked off. The drain plug is in a ridiculous spot. After some googling this pan looks different than others. The engine says its a Z24. Here are some pictures. Any help would be greatly appreciated. Quote Link to comment
datzenmike Posted July 28, 2023 Report Share Posted July 28, 2023 Simple, that is not a 4x4 oil pan. That's a Z24 2wd oil pan. Ask your buddy if he swapped the engine. Maybe the old engine is around and you can get the oil pan off of it. I only have the oil pan picture for an L series 4x4 720 so you'll have to just imagine that the lower sump on the right in the picture below is actually on the left where Z series engines had them. If you look under from the front you'll see that the differential is mounted slightly to the driver's side leaving more room on the passenger side for the oil pan. Looking forward from the rear the lower bulge sump would be to the right and the differential itself slightly off set to the left which it is. A Z22 4x4 pan should also work. Be sure to get the pick up tube that comes with it. Quote Link to comment
IronFromIce Posted July 28, 2023 Author Report Share Posted July 28, 2023 Awesome thanks for the info, sadly my buddy got it from someone else and wasnt interested in messing with it but my local yard has a fresh 720 that i believe is 4x4 so ill see if i can get that one. Quote Link to comment
datzenmike Posted July 28, 2023 Report Share Posted July 28, 2023 Can't be a 1980. That was the only year the L20B was used. Quote Link to comment
