asandberg6 Posted July 8, 2023 Report Share Posted July 8, 2023 Hello, first post and a little off topic. I swapped my 1996 Metro to a Datsun 1200 carb. It runs very well and ive been commuting in it for two weeks. The plugs are showing a lean and i would like to re-jet it. Can anyone help me find some jets that will fit? ebay carburetor 1 Quote Link to comment
datzenmike Posted July 8, 2023 Report Share Posted July 8, 2023 Are you sure? Carburetors simply mix fuel in proportion to the air passing through it. A larger engine shouldn't need more or less. To the carburetor a larger engine is the same as a smaller displacement revving much higher. I would check that the jets are not restricted with a small bit of debris or dirt which would make them in effect smaller. While they are out have a look at the size stamped on them and record this. If you go to Amazon you can buy a range of carburetor jets (for under $15) for Webers or motorcycles for fine tuning the mixture. For example if you have a 100 jet, get a 90 to 110 set and you can go richer or leaner. These are for Mikuni and range from 88-128 but again this is just an example. I think most Japanese jets are the same thread. For my R1 carburetors I bought smaller than needed and selected a drill size that was correct and drilled them out to suit. I did have a wide band so perfect mixtures were possible unlike reading the plugs. Quote Link to comment
asandberg6 Posted July 13, 2023 Author Report Share Posted July 13, 2023 Ordered these jets and they fit. Installed a #100 in the primary side as the original was unmarked and i did not want to go any leaner. Will drive it to work tomorrow and see how it burns. 1 Quote Link to comment
