leo Posted April 26, 2023 Report Share Posted April 26, 2023 Hi everyone, I have a problem with the headlights in my 1986 720. Turning on my high beams stops all of the headlights from working. At first the normal headlights work but when I turn on the high beams all the headlights turn off. Then when I go to turn on the normal headlights again they no longer work. To get them working again I have to disconnect the headlight cable from the battery and reconnect it. Ive checked the fuses in the fuse box and they are all fine. Any help would be greatly appreciated! Quote Link to comment
datzenmike Posted April 26, 2023 Report Share Posted April 26, 2023 Sounds like the headlight relay. The relay should be mounted to the far right side top of the fuse box Above the headlight fuses. Quote Link to comment
leo Posted April 27, 2023 Author Report Share Posted April 27, 2023 Thanks for the reply 🙂 I have two relays above the fuse box, one is black with 5 pins (Jideco 25230-C9900) and the other is blue with 4 pins (Jideco 25230-89975). Do you happen to know which one is used for the headlights? Or are both used? Quote Link to comment
