Yinzer Posted March 17, 2023 Report Share Posted March 17, 2023 (edited) ....by swapping out the Cap/Rotors ? If not, why ? TIA Edited March 17, 2023 by Yinzer Quote Link to comment
datzenmike Posted March 17, 2023 Report Share Posted March 17, 2023 I don't see why it would work. The 8 plug is wider than the 4 wire to make room for the extra plugs. This is a Z series 8 plug distributor?The Z rotor is screwed onto the distributor spindle and won't fir the L20B one. If needing an 8 plug distributor get another from an '81-'82 Z22 720 or an '82-'83 S110 200sx or from another Z24. Might be better to ask you what you want to accomplish as there may be a better way to do it. 1 Quote Link to comment
Yinzer Posted March 19, 2023 Author Report Share Posted March 19, 2023 On 3/17/2023 at 8:11 AM, datzenmike said: I don't see why it would work. The 8 plug is wider than the 4 wire to make room for the extra plugs. This is a Z series 8 plug distributor?The Z rotor is screwed onto the distributor spindle and won't fir the L20B one. If needing an 8 plug distributor get another from an '81-'82 Z22 720 or an '82-'83 S110 200sx or from another Z24. Might be better to ask you what you want to accomplish as there may be a better way to do it. I need a new Vacuum Advance. There about $75 and it's probably easier (not sure to buy a used distributor w/vacuum advance on it and swap them out. Dunno...... ?? I'm trying to learn. Is it easier/cheaper to do it this way ? Quote Link to comment
