K Wagon Posted February 17, 2023 Report Share Posted February 17, 2023 Hey guys.. new here. I am in the process of K-swapping my B310 wagon, and I need to upgrade the differential to handle the torque. I've read on here about swapping a h190 from a 620 and using the original side gears for the axles.. I called my friend who has a 1981 620 and he says he thinks I need special tools to do such a job. Is this true? and if so, where do I get these tools? Quote Link to comment
datzenmike Posted February 17, 2023 Report Share Posted February 17, 2023 '81? if the year is correct it's a 720. Does it have rectangular headlights? It's a 720. Forget the 620 and the 720. Your H-150 side gears won't fit it and neither will your axles. You are stuck with 6 lug rims and the gears are way too low for a KA swap. Get the axle out of a 510 wagon. It should fit better width wise* and is H-190 and 4 lug rims. Other H-190 and 4 lug rim options are... The 810 wagon. It's an inch wider per side. The '81-'84 Maxima wagon is even wider at 2". The '82-'83 S110 200sx maybe 1 1/2" wider per side The '84 S12 200sx is maybe 1 1/2" wider per side *I could only compare wheel tread measurements and not the actual WMS (wheel mounting surfaces) where the rim touches the brake drum. Most Datsuns are zero off set but you would have to measure accurately and see. Wheel tread in the 210 is 51.2" the actual WMS may be more or less. 1 Quote Link to comment
K Wagon Posted February 17, 2023 Author Report Share Posted February 17, 2023 My friend just has a 720, I can purchase a rear end from a 620.. but if I can't swap side gears then I guess I'll look for different rear ends Quote Link to comment
K Wagon Posted February 17, 2023 Author Report Share Posted February 17, 2023 47 minutes ago, datzenmike said: Forget the 620 and the 720. Your H-150 side gears won't fit it and neither will your axles. I'm positive I saw a comment from you saying someone could swap a H-190 from a 620 into a B310.. but maybe it was a H145 and not a H150 Quote Link to comment
datzenmike Posted February 17, 2023 Report Share Posted February 17, 2023 You could but nothing on the B-310 (210) axle will fit it. The 620 axle would still have 6 lug rims. The axle could be drilled for 4 lug and maybe the 510/810 maxima wagon drums would fit or the S110/S12 drums? The 620 drums are 10" I don't know what the cars are, otherwise drill the drums for 4 lug. It could be done. The most common differential for the 620 is 4.375... a little revvy for the larger KA. A 3.70 would work better I think. Quote Link to comment
K Wagon Posted February 17, 2023 Author Report Share Posted February 17, 2023 This is true. Although K series love to rev high - VTEC baby. My transmission im using does have an overdrive too. Is the axle on the 620 just a bolt off, bolt on? Or do I have to custom fab connection points to the chassis? Quote Link to comment
datzenmike Posted February 17, 2023 Report Share Posted February 17, 2023 25 minutes ago, K Wagon said: My transmission im using does have an overdrive too. Is the axle on the 620 just a bolt off, bolt on? Or do I have to custom fab connection points to the chassis? If you are thinking of the 210 transmission... it won't fit the KA and it wouldn't last if it did. The 620 uses a leaf spring on each side so 4 mounting points. Your 210 uses coil springs and four link to locate the axle on the car. I guess you could cut all the link and spring mounts off the 210 and weld onto the 620 axle... a lot of geometry to get right. The '82-'83 S110 200sx and the '84 S12 both had coil spring and link rear axles. See my list. So these are a lot closer Quote Link to comment
K Wagon Posted February 17, 2023 Author Report Share Posted February 17, 2023 I'm using a miata 5 speed, should be fine for the power I'm using I have some time to look for the sx and s12 rear axles.. any ideas where to look? They are rare Quote Link to comment
datzenmike Posted February 17, 2023 Report Share Posted February 17, 2023 You must have an adapter plate to mate Miata to KA???? Why not get a 2wd D21 Hardbody KA 5 speed???? Easier, more than strong enough and cheaper. Quote Link to comment
K Wagon Posted February 17, 2023 Author Report Share Posted February 17, 2023 I'm using a K20z3, honda motor. There is an adapter plate for the motor to the miata transmission Quote Link to comment
datzenmike Posted February 17, 2023 Report Share Posted February 17, 2023 Gotcha. I know of it. Quote Link to comment
K Wagon Posted February 17, 2023 Author Report Share Posted February 17, 2023 Okay so just to end this thread topic Mike, I cannot put my b310 side gears and axles into a 620 rear axle, I have to look for other rear axles Quote Link to comment
datzenmike Posted February 17, 2023 Report Share Posted February 17, 2023 34 minutes ago, K Wagon said: Okay so just to end this thread topic Mike, I cannot put my b310 side gears and axles into a 620 rear axle, No, they will not fit. 34 minutes ago, K Wagon said: I have to look for other rear axles Yes. Quote Link to comment
K Wagon Posted February 17, 2023 Author Report Share Posted February 17, 2023 I'll probably just go with an 8.8 from a crown vic and modify the links. Thanks for your help Quote Link to comment
datzenmike Posted February 17, 2023 Report Share Posted February 17, 2023 You need to measure the wms to wms distance. Mustang may be closer? Has to be close to the 210 for width. The 8.8 is likely 5 lug rim so what you going to do about that? Is the Viky coil or leaf spring? A lot more discovery is needed for this. Quote Link to comment
K Wagon Posted February 17, 2023 Author Report Share Posted February 17, 2023 New rims and tires for the back. Viky is coil spring 😄 Quote Link to comment
datzenmike Posted February 18, 2023 Report Share Posted February 18, 2023 How wide? Five lug? Quote Link to comment
K Wagon Posted February 18, 2023 Author Report Share Posted February 18, 2023 5 lug, 65 inches Quote Link to comment
