averdi Posted February 8, 2023 Report Share Posted February 8, 2023 Hey all, Just finished adjusting the valve lash on my ‘81 B310 and I went to start the car up and upon pressing the gas, the pedal hit the floor and wouldn’t come back up. Checked out under the hood and the throttle cable had come loose from the carb. I put it back in but it doesn’t seem to want to stay on the guide and keeps slipping off after going full throttle. I’m not sure how tight it was beforehand, but it also seems to have more slack than I think it should. Just thought I’d see if anyone else has had a similar issue or could point me in the right direction. thanks in advance Quote Link to comment
datzenmike Posted February 9, 2023 Report Share Posted February 9, 2023 Did you have the air filter off!!!!!! Get a flashlight and look down the primary barrel. Is anything blocking the throttle plate from closing??? Quote Link to comment
averdi Posted February 9, 2023 Author Report Share Posted February 9, 2023 Yea I had the air filter off. Nothing in the primary but the throttle plate is open slightly and it seems like the throttle lever isn’t travelling as much as it should. Quote Link to comment
ToastyBass Posted March 7, 2023 Report Share Posted March 7, 2023 Hi there! I just got my A14 running again last night after doing all seals (I'll be getting rear main with the 5-speed swap, new clutch, and flywheel resurface) Needless to say, carb was removed and now I have some freeplay in my A-pedal. I have a hard copy of service info for a '75 B210 and a digital copy for '81 B310. For the B310, the adjustment I have tells you to adjust the pedal distance from the floor to 109mm or 4.29" via the stopper bolt resting below the cable-to-pedal attachment point. Tighten stopper bolt lock nut. It then says to adjust the cable's outer case away from the carb (the metal cap of the sleeve by the carb, loosen the hold-down screw to adjust) "making sure that the throttle lever is returned to idle position." Thinking about it more, I'm not 100% sure this will help, I wouldn't mind looking up anything you may need, though Quote Link to comment
datzenmike Posted March 7, 2023 Report Share Posted March 7, 2023 Put a brick on the pedal to hold it down. Adjust the throttle at the carburetor so that the throttle plates are fully vertical and open. When released the pedal will rise to what ever height. Quote Link to comment
averdi Posted March 12, 2023 Author Report Share Posted March 12, 2023 Thanks a ton y’all. I’ll let you know by the end of today how it goes! Quote Link to comment
averdi Posted March 17, 2023 Author Report Share Posted March 17, 2023 Well I ended up just going with a Weber 32/36 swap instead of trying to get the hitachi sorted since that was the plan for the future anyways. So far it’s looking good, install was pretty simple. Think I’ll rebuild the hitachi whenever I can find a rebuild kit for it. Thanks for the help y’all. Quote Link to comment
