Russmanlive Posted October 2, 2022 Report Share Posted October 2, 2022 Hello. I have a 1975 B210 with the a14 engine manual trans. I parked it for lunch the other day and it would not start afterwards. In messing with it, if I turn the ignition switch to start, the car will turn over and start. Once I let off of the switch, it promptly dies. I can start it and turn the switch to disengage the starter and it will continue to run but once I completely back off of the switch to the run position, it dies. On the wiring on the back of the ignition switch, I have no power to the Yellow/Black stripe wire or the Black/Red stripe wire when the ignition switch is in the run position. The wiring Diagram shows the Yellow/Black stripe wire goes to the Interlock Relay. I can't find this relay and I think this is the problem. Any help locating this relay or figuring out the problem would be greatly appreciated. Quote Link to comment
datzenmike Posted October 2, 2022 Report Share Posted October 2, 2022 Can you find the ballast resistor? It will be right near or beside the ignition coil. One wire comes from the ignition switch the other side goes to the + terminal of the coil. Make a short jumper wire and connect across the two terminals. Start the car.... if it keeps running when the ignition switch returns to the on, or run position, then the ballast is bad. Possibly loose wire? check and replace if needed. The car will run wired this way but not at all a good idea as the coil will over heat. This is just a diagnostic test so remove the jumper wire when done.. Quote Link to comment
Russmanlive Posted October 3, 2022 Author Report Share Posted October 3, 2022 I have no power to either side of the ballast resistor. The Black/Red stripe wire from the ignition switch goes to the ballast resistor and is dead. Quote Link to comment
datzenmike Posted October 3, 2022 Report Share Posted October 3, 2022 Yeah, I was hoping. Looks like the ignition switch is bad. Quote Link to comment
Russmanlive Posted October 3, 2022 Author Report Share Posted October 3, 2022 I have three ignition switches and it does it with all three. I also don't have power from the interlock solenoid but I can't find it and I don't know what it looks like. Russ Quote Link to comment
