sdsurf Posted December 10, 2008 Report Share Posted December 10, 2008 1. Is the front suspension on a 520 the same as a 521? 2. is the frame (front half) the same so other than mounts and L-series will drop in? 3. Is the rear end the same? There is one I may get and sit on but I want to know if the L-series/5spd swap is as easy as in a 521... Quote Link to comment
Pacific coast Datsun Posted December 10, 2008 Report Share Posted December 10, 2008 1. yes 2. yes 3. should be. gears in them not certain..4.88's ? Quote Link to comment
yellowdatsun Posted December 12, 2008 Report Share Posted December 12, 2008 1. is yes 2. is actually no. The frame on the front of the 520 is shorter than that of the 521. Quite a bit shorter. 3. The axle is the same, gears are different. Lower gears in the 520 axle. Quote Link to comment
Bob3 Posted December 12, 2008 Report Share Posted December 12, 2008 My 520 is different than any other 520 or 521. :thumbsup: 1. No, I've got Miata front suspension & brakes! :D 2. No, I cut all of that old :poop: off. :eek: 3. No, mine is missing the leaf springs. :rollseyes: Never mind my 520 is kinda odd! Quote Link to comment
