Jeffthe620 Posted August 17, 2022 Report Share Posted August 17, 2022 Hey everyone, I just recently pulled my truck out of the garage after about 2-1/2 months of working on it and it’s started up just fine and runs good, but when it idles it chops like it has a cam (it does not) and lightly smokes a white/blue color. Any ideas what’s wrong? Quote Link to comment
datzenmike Posted August 17, 2022 Report Share Posted August 17, 2022 Black exhaust is too rich as in the choke on Blue exhaust is incomplete burning of oil. Possibly worn valve guide seals or worn rings. May smoke if sitting a long time and oil has more time to run down the worn valve seals. Depending on amount of wear it may burn off in a short while and not be noticeable. In extreme oil burning conditions the smoke can appear white. White is usually steam from coolant leak, usually a head gasket. This would explain the poor idle also. Let it run or better, take for a drive. If it over heats or shows a coolant loss then this is your answer. Quote Link to comment
Jeffthe620 Posted August 17, 2022 Author Report Share Posted August 17, 2022 Thank you mike, I’ll take it on a drive ASAP. how hard is a new head gasket on a L20B? Quote Link to comment
datzenmike Posted August 17, 2022 Report Share Posted August 17, 2022 Last one I did was $30 CDN at NAPA and a morning to change. Make sure you know how to properly block the timing chain tensioner so it can't possibly pop out or add another 4-6 hours to fix and a timing gasket set. First, make sure it's is a blown gasket. Smoke can have several causes that are not blown head gaskets. Quote Link to comment
Jeffthe620 Posted August 17, 2022 Author Report Share Posted August 17, 2022 Thanks for the info, it seems like it might be one of the many problems but I’m going to try to run some tests today Quote Link to comment
