Sameer Posted May 7, 2022 Report Share Posted May 7, 2022 Got a 1980 datsun about a month ago and have been cleaning up the engine bay and refreshing the motor, putting the cooling system back together today and can't remember what went on the front of the thermostat up and to the right of the coolant temp sensor (imgur link isn't working otherwise I would add a image) If anyone knows or has a diagram it would be appreciated. Quote Link to comment
datzenmike Posted May 7, 2022 Report Share Posted May 7, 2022 On the front? probably the coolant by pass hose outlet fitting. It will have a short hose big as my little finger that goes to a metal pipe. The pipe forms a Y with one end going to the intake at the base on the carburetor. The other end goes down the front of the timing cover to the lower radiator hose inlet to the water pump. The larger threaded hole on the side is the TVV (thermal vacuum valve) for the EGR. Quote Link to comment
Sameer Posted May 8, 2022 Author Report Share Posted May 8, 2022 thanks, deleted the egr, the tvv and all other emissions components just piecing everything back together got that back on now time to mount my radiator. Quote Link to comment
datzenmike Posted May 8, 2022 Report Share Posted May 8, 2022 So did I. Plugged with something from a KA24E intake. Looks clean Quote Link to comment
