Eric V Posted March 30, 2022 Report Share Posted March 30, 2022 After installing a new master clutch cylinder on my son's '67 520 the flare fitting leaks. I think I may need to cut it back and re flare the end but I'm not sure if it is a single flare, or a double. Also, is the line size 3/16? Quote Link to comment
Dave 240Z Posted March 31, 2022 Report Share Posted March 31, 2022 Double flare for brakes. Quote Link to comment
Stoffregen Motorsports Posted March 31, 2022 Report Share Posted March 31, 2022 Flaring tip - Never cut brake tubing with a chop saw of cutoff wheel. Cut with a band saw or a hack saw, then true it up with a belt sander or a file. Cutting with a chop saw hardens the tip and can cause it to crack when flaring. Also, I have had problems with tubing these past couple years. There's a welded seam inside that, if not smoothed out, can cause a leak. I made a flare lapping tool to get the high spot out. Yet another tip, when flaring, don't flare all the way with the flaring tool. Go like 90% and let the remaining 10% happen when tightening the nut. A tiny bit of anti seize on the flare and threads will help with this. 3 Quote Link to comment
Stoffregen Motorsports Posted March 31, 2022 Report Share Posted March 31, 2022 Yes, 3/16" Quote Link to comment
