Single flare or double?
Eric V
  • Replies 3
Flaring tip - Never cut brake tubing with a chop saw of cutoff wheel. Cut with a band saw or a hack saw, then true it up with a belt sander or a file.  Cutting with a chop saw hardens the tip and can cause it to crack when flaring.
Also, I have had problems with tubing these past couple years. There's a welded seam inside that, if not smoothed out, can cause a leak. I made a flare lapping tool to get the high spot out.
Yet another tip, when flaring, don't flare all the way with the flaring tool. Go like 90% and let the remaining 10% happen when tightening the nut. A tiny bit of anti seize on the flare and threads will help with this.
  • Like 3
