rnscustom Posted February 18, 2022 Report Share Posted February 18, 2022 I have an 82 vin 720 pickup , has the z24 so it’s a rebuild from a couple trucks I assume . Came with a spare rear that I need to use the gears out of . The one in the truck is 2wd gears and she just locks up in 4x4 . These are the numbers on the ring out of the spare ( according to the po belong with the front gears ) JH37:9 AB 3 9 21 . Anyone know what this set is and if they were 4x4 gears . Not sure I can follow any tags on the truck . Thanks everyone on the head and timing issues . Seems fine , need to time it but been busy getting back to regular work , Richard Quote Link to comment
datzenmike Posted February 18, 2022 Report Share Posted February 18, 2022 A Z24 in an '82 has been transplanted. October '82 and up are '83 model year, and have Z24s, Z20s and SD25 diesels. The Z24 4x4s were 4.11 with a few 3.889. And the rear axle was a C-200. Earlier 4x4s were 4.375 and H-190 differentials. The C-200 is a Salisbury type with bolt on cover plate on the back with the gears inserted into a one piece axle housing and set. The H-190 is a bolt in from the front, removable 'third member' axle. Yes the front differential ratio must match the rear ratio. Your JH37:9 AB 3 9 21 is a 4.11. There were 4.11 C-200 and H-190 gear sets. The 4.11 ratio H-190 was used in some of the 2wd. C-200 is 200mm diameter ring gear and larger will indicate relative strength. The H-190 is 190mm diameter ring gear. Needless to say C-200 and H-190 R&P gears do not swap. Quote Link to comment
rnscustom Posted February 23, 2022 Author Report Share Posted February 23, 2022 Thanks again , I do have the c-200 bolt on cover . The gears are a little crusty so I’m going to clean them up and hope for the best . The pinion is still in , tried driving it out but no go , have to put it in the press . Gotta get back to regular work so the rear will wait a little while . The wedge I made for the timing chain worked well , kinda curved and tapered . I think it also held the tensioner in so I didn’t have to put much pressure on it ., can post it if you think it would be informative .Anyway you’ve been a great help , thank you !! Im probably going to scrap what is left of the spare diff. ( no gears or axles ) but if someone can use it I’ll post it for free ( shipping on them ) Quote Link to comment
datzenmike Posted February 23, 2022 Report Share Posted February 23, 2022 The C-200 gears have to be 'set' with gauges and shims for correct tooth contact. Or at least checked. The H-190 can be taken out as a unit and swapped. I made this silly thing for a Z24. It's springy and when pushed down between the chains and guides pushes directly on the tensioner through the chain. Quote Link to comment
rnscustom Posted February 28, 2022 Author Report Share Posted February 28, 2022 Yours is a bit nicer but exactly the same . Worked great . Thanks again for all the help , Richard Quote Link to comment
