banzai510(hainz) Posted December 7, 2008 Report Share Posted December 7, 2008 my # is 253 653 3690 you might have the wrong timmingplate mount(diizy pedastals). There were 2 types. You either have to move the spindal a tooth in the direction you want it. or find the correct mount. or remove the 10mm bolt and just get a MINI C clamp to hold the dizzy down till you figure this out. But if moto is TDC 0 on the pulley and oil spindal is in the 11.28 position you have everything correct. then its the above statement Quote Link to comment
