Valvebounce Posted August 11, 2021 Report Share Posted August 11, 2021 I've started trying to fit my windows to the doors on my truck. I scored a pair of USDM one piece windows after a tip off from someone on here. (No quarter vent window) with the window in place, I cant seem to get the front most window track into place. My Haynes manual says to just pop the lips seals out, unbolt the glass and slide it out or in. What has everyone else done? I've just had them tinted too. So I'm walking on eggshells not to damage the film which trying to do it. Quote Link to comment
Moist Lightning Posted August 12, 2021 Report Share Posted August 12, 2021 When i took them out I just unscrewed 3(maybe 4) bolts and removed the window with the metal piece it slides into(window track). Should be able to do the opposite. attach the metal piece to the window, lower window into door, attach 3 bolts and done. 2 Quote Link to comment
Valvebounce Posted August 18, 2021 Author Report Share Posted August 18, 2021 Bingo! That worked a treat!!! Cheers @Moist Lightning 1 Quote Link to comment
