My 1972 521 flat bed
yenpit
I grabbed this truck up in Fall 2019, found LOCALLY, don't know where it might have come from!  In the garage, you can see the tail gate of the 1980 720 parts truck, where I have already pulled the 77k original mile L20B, the matching 5speed & the matching rear axle.  I have a Weber 32/36 for it & am currently detailing the engine before poking it in.  The original doors are badly cut up inside & both have some rust & bondo, so found a pair of rock solid original paint doors in white.  Original lower front valence is the same story, badly cut up (tow behind bar??), so found a nice straight one in tan!
  • Like 3
  • Replies 1
720 seat had to be narrowed at the top of the seat back, then full on custom red & black Tartan inserts on the seat & the door panels!  Will eventually have the dash top pad & headliner done, perhaps with some simple red stitching.  I'm hoping I can fit the 1980 720 OEM rubber floor mat, as it's in decent condition, but I also have a NEW carpet set in black if not!
